RCU Forums - View Single Post - another 2nd gear shift ?
Old 09-07-2005 | 11:09 PM
rolland
Default RE: another 2nd gear shift ?
There is also the possibility that the set screw has backed of enough to cause the shift unit to slip on the shaft.
The most common place to check the temp is down the hole to the glow plug. The glow plug area is going to give you the most accurate reading.
rolland
