RE: Ongoing Poll for your favorite flight simulator! VOTE!
G3 now has photo scenery, although personaly - I prefer the 3D scenes.
There is a HUGE list of improvements in the latest G3 update - maybe this poll should be re-done. [X(]
Actually, lets wait until the GMax new plane importer is done before re-doing this poll.
Here is the list of new features and bug fixes for .410:
NEW FEATURES:
PhotoField airport technology
New airports: Sod Farm & Grassy Flatlands (PhotoFields)
Default airport is now Grass Flatlands
Airport editor: Support for PhotoField airports (render to depth-buffer, cast shadows, sun halo, fixed camera)
Airport editor: "Drop aircraft on reset" and "Initial velocity" properties added to airplane spawn points
Airport editor: New Pilot Preview window
Aircraft editor: "Launch Method" property added to aircraft
Import raw panoramic images (Simulation->Import->Raw Panoramic Image)
Expanded graphics card compatibility
Time scale parameter in physics settings
Rolling resistance and friction coefficient factors added to wheels and surfaces
Camber thrust model for tires
Flexible helicopter landing skids
General improvements to ground handling & steering model
Converted user manual from HTML and Word formats to Adobe .PDF format
Initial hand-launch direction is now determined by pilot spawn orientation instead of wind direction
Automatically generate new collision files when a 3D model has changed
Added another servo to the smoke component to control smoke more effectively
"Remember aircraft position" lets you temporarily save the aircraft position and orientation to be used on aircraft reset
Show environment map on shiny breakoff parts
Camera behavior during events modified for "fixed camera only" airports
New window modes: normal (resizable), maximized normal, maximized full-screen (menu bar only), full-screen exclusive
New custom channel mapping dialog
Aircraft specifications moved to tab in selection dialog
Airport selection dialog uses panoramic previews
Grouping options in airport/aircraft selection dialogs
"Custom" folder in airport/aircraft selection dialogs
Redesigned multiplayer "Join" dialog
Controller numbering in the Select Controller menu
"Show pilot nametag" option on MultiMode and Event menus
Roll/zoom added to TrackIR view
E3D - Flap Mixing: added flaperon and spoileron mixing
Launcher: online updates can be cancelled and resumed (starting from the last completely downloaded file)
FIXED BUGS:
Eliminate texture cache (RealFlight.cmp-tcache) that is causing startup hangs
Crash sometimes occurs when all wheels are broken off before a reset
Collision detection/response code needs more optimization
Behavior of lightweight breakoff objects needs improvement
Loading of collision meshes needs optimization to improve load times
Some complex airport objects need optimized collision meshes to improve collision engine performance
Numerous fixes and optimizations for vehicle visual meshes
Engine handling bug for airplanes with multiple electric motors
Planes "jump" when a piece breaks off
Proximity engine performance and runway detection need improvement
Dirt squares and corners should be "runway" object types
Airplanes are sometimes identified as helicopters
Turbine engine sounds don't stop when engines are separated from aircraft
Smoke continues emitting from smoke components after breakapart
Engine sounds keep playing at breakoff location after breakapart
Some static objects have bad scaling values the first time they load
Attempting to change zoom level in Keep Ground In View mode affects zoom level in manual zoom mode
Autozoom level not persistent
“Look At” option combined with pivot camera mode can cause camera to pivot around incorrect aircraft
"Look at windsock" looks at the base of the pole, not the sock itself
"Look at windsock" always looks to first windsock, even when multiple windsocks are present
Walk mode prevents “Look at Windsock” from working correctly
Walk mode keys (W, A, S, D) are not functional while a VFI is playing
Mini-viewports can't quicklook at objects
Camera spring level setting is treated as incorrect data type
Change default wind setting for all airports (except slope soaring airports) to zero MPH
Wind Variation setting is a percentage, but constraints allow values from 0-200
Crash and other bad behavior when using two G3 Controllers
Multiplayer host dialog accepts invalid port numbers
Changing shadow quality setting does not affect recordings/multiplayer participants that are already loaded
Name tags don't appear consistently for remote participants
Chat Gadget title is not updated after exiting the first multiplayer session and joining another
Chat Gadget text size setting has no effect
Clicking on a viewport in MultiMode doesn't always work
Aircraft editor: When saving, no warning before overwriting an existing custom aircraft
Aircraft editor: Dialog is not resizable but should be
Aircraft editor: No user prompt to save changes after renaming a component and attempting to exit
Aircraft editor: Under certain circumstances, two rotor heads appear
Aircraft editor: Creating multiple rotor components is permitted
Aircraft editor: Cannot delete tail boom component
Aircraft editor: "Display metric units" menu option not persistent
Aircraft editor: Bad default value for "Location in Parent" and other properties
Airport editor: Crashes when moving windsock to a new folder
Airport editor: Various bugs with Reset Window Position feature
Airport Editor: "Fit Object to View" behavior needs improvement
Airport editor: Read only items are not grayed out
Airport editor: Edit menu and context menu do not always contain the same functions
Airport editor: Following properties need improvement: sun position, sky color, shadows
Airport editor: Control objects are resizable using the hotkey, even though they have no scale
Airport editor: Set As Default should not be available for airplane and helicopter spawns
Airport editor: Misc. other bugs
Remove camera translations after exiting airport editor
Recordings continue playing in airport editor
Aircraft selection dialog is resizable but should not be
"Save Color Scheme As..." does not warn before overwriting an existing color scheme
Airport MRU does not include most recent airport if a new one is loaded to play a VFI
Help menu items do not appear while in MultiMode
Show Keyboard Commands gadget contains some unsupported hotkeys
Eliminate event previews
Events timer countdown displays tenths as hundredths
Sierra Nevada Cliff airport: heli cannot be seen from pilot spawn
Default scale is wrong for Adair Runway and Grassy Field airport objects (AO5)
Clean up airport object folder hierarchy for G2 airports
Sim does not respond properly if Windows monitor resolution setting is changed while the sim is running
Lighting is different in the binocular view than in the main viewport
Sky color needs improving for all airports
Forest rendering needs optimizing
"Brightness" setting needs to have more effect
Make Futaba channel mapping the default configuration for the controller interface
Remove "Flying the Obstacle Course" recording from installation directory
Naming problem with Rossi .90 ducted fan torque generators (missing space)
Missing projected scenery object does not give an error message
System message settings not always enforced
System messages should be removed when entering the airport editor
Kontronik motors have zero mass
Crash caused by certain turbine configurations
Control objects visible while simulation is running under certain circumstances
Sun Azimuth/Latitude/Wind parameters aren't being copied when creating a new airport
Sometimes VFI narrations are muted after loading several VFIs
Various aircraft and airport description errors
Misc. viewport and gadget bugs
Misc. spelling and grammar errors
Launcher: Online updates dialog is unresponsive during updates
Launcher: Online updates should detect incomplete files in download cache and react appropriately
Launcher: Crash occurs in certain cases after updating from an early version to a later version then back
Launcher: Improve online updates error checking and error reporting
Launcher: Improve online updates network compatibility (especially DirecWay satellite internet connections)
Launcher: Assemble information (in tech support dialog) should include fileread.ini, should not include airports.ini
Launcher: Misc. other fixes and dialog cleanup
AIRCRAFT CHANGES:
BLT Park Flyer: Reduced rudder throw
E3D: Strengthened vertical and horizontal tail
Extra Special: Increased tail strength
Ultra Sport: Added retracts
Yak-54: Updated description
Piper Cub (AO1): Removed aileron-rudder mixing and increased right thrust to 2 degrees
DC-3 (AO2): Removed aileron-rudder mixing and increased aileron throw
PT-19 (AO2): Adjusted downthrust value and engine location to improve takeoff behavior
A-10 (AO3): Added wing incidence, no longer climbs at full throttle
P-47 (AO3): Reduced elevator throw, increased right thrust to 3.5 degrees, moved CG forward
Sukhoi - 3D Version (AO3): Added mass to various components, increased tail strength
Edge 540 (AO4): Modified tail and rudder strength and mass
Extra 330S (AO4): Increased wing and tail strength
Nobler (AO4): Reduced rudder throw, removed smoke servo, set up visual rudder component
Contender (AO5): Removed smoke servo
Double Whammy (AO5): Removed throttle servo, renamed vertical fin component
Gee Bee (AO5): Added smoke to glow version, changed electric sound profile, reduced elevator throw, added right thrust
KingCat (AO5): Added more flap-elevator mixing to fix pitch-down problem, increased wing strength
Sea Fury (AO5): Moved CG forward, reduced elevator throw
Shoestring (AO5): Removed smoke servo
Viper (AO5): Removed smoke servo, assigned throttle servo to exhaust smoke
