Aviation Design Mirage
Brian
The basic kit costs 760 Eur, with cut wood parts it costs 830 Eur and if you add 530 Eur you will receive the kit with everything glued in the fuse (formers air inlet some work done on the wings too). The quality is very good, nearly as good as Avonds
No bypass or tailpipe is included, the fuse has no panel lines.
The scale legs are at 330 Eur and you can also buy wing and centerline tanks
Florent
