RCU Forums - View Single Post - engine that runs backwards
Old 10-28-2002 | 12:13 AM
MrMotor
Default Reverse Rotation Engines
It would help to know the approximate size range of the engine you want to run backwards. All reed valve engines will run either direction just fine. Some shaft rotory valve engines have reverse rotation shafts available. If the engine has a detachable front housing it can be rotated 90 degrees and get close to equalling a reverse rotation shaft in timing.
