RE: Venom SmartTemp Fail-safe
I'm considering buying a VST.
I hear a lot of different things about it: shorter radio range tec.
About the temp issue: why didn't anyone put the sensor part of the wire ( I think it's the red part) in a cup of boiling water?
It should read 100 degrees C ( or 212 F).
You can do the same with a IR heat gun...than you can compare..
