RCU Forums - View Single Post - Efficient/Powerful mix?
Old 09-12-2005 | 01:00 PM
exeter_acres's Avatar
exeter_acres
Default Efficient/Powerful mix?
I'm using an AXI 2208/34 with the HL EVP setup....Electrifly 640mAh, 3s1p batt
getting it to work pretty well...but very short flight times....\
Curious how others are setting their mix curves??
Do you set for more RPM's and less pitch, or more pitch with a bit less RPM's
I'm trying to find a balance, just curious what P-curves and T-curves people are using..
I'm using a 9C radio with the Governor mode (Norm, Idle 1, etc)
Inverted Torque rolls sure get their attention at the field!
