RCU Forums - View Single Post - Problem with throttle control on my Mayhem RTR...
Old 09-12-2005 | 01:38 PM
rwong21
Default RE: Problem with throttle control on my Mayhem RTR...
ORIGINAL: foxy42
Allow me to intercept this one...
1) If your car wants to move when yuo turn it on, your clutch springs are not wokring properly (not likely), or your idle is too high.
2) Should be about 1mm, give or take .25mm
3) If you mean your engine stops when you press the brake, then your clutch is having a problem or your idle is too high, just like answer to question 1.
If I've understood correctly your reasons for asking...
Ok..I only ask you one question.
When you press the brake and the carb close too much (cannt give a lot of air to enter) and the motor stop? Wath is the problem.?....the clutch!!!!.....of course the answer is not...maybe i'm wrong.
I only try to help him.....but you make more confusion. My question number 1, he cannt answer yet...and you answer for him......mmmmmmm that is great help. []
Please let him answer the three question and you and me can discharge the posibility.
