Originally posted by tnewman
USE MORE ELEVATOR.
When rolling to the inside of the circle all you have to make the turn is Elevator...because the rudder inputs go the wrong way for the turn.....Just use enough rudder to keep the nose up and no more and then lean on the elevator a little more.
Good Luck
Troy Newman
Thank you thank you thank you....!! This whole time I thought that you had to use a lot of rudder to guide it around, and I too think that rolling to the outside is easier. Like tool said, I can do a great rolling circle rolling to the outside, but not to the inside. This is probably why.
Thanks a bunch,
torque_roll
