RE: telemaster build
I have been thinking of making ythe wing very close to flat,and using one servo on airlons seeing that it is a trainer.How did you fix the stab?did you make a new base with it higher in front?About the only thing I do not have is a sim.My wife said a new radio or that I took a new futaba 6ax pcm I think it was the new one in the magazine section,aleady have 2 6da's so what the heck seeing the new one has 6 model mem. I just might see about using the other servos and rec as flight packs for the other 2 planes.My extra outer ribs came from bte today Now I can use the new ribs to put from the leading edge to the spar on my venture in between the other ribs so the covering won't say less weight than sheeting.
