RE: Woodburn, OR?
Bruce,
If I recall correctly from my Willamette U. days, Woodburn is a bit less that halfway from Salem to Portland, just East of I-5. If this is correct, there may not be anyone closer to you than ten to twenty miles away. I can tell you that there is a fairly active group of Control Line flyers in the Salem area. Additionally, the Northwest Fireballs in Portland are a going concern as well. While I'm not certain of contact names/phone numbers, I'm certain that the local hobby shops might help you out.
You might also head over to McMinnville this weekend for the "TEAM Country Classic 2005" at the Evergreen Aviation Museum to see if you can hook up with other CL flyers. For further information, check out the [link=http://www.clstunt.com/htdocs/dcforum/DCForumID10/267.html]Country Classic[/link]. Just follow the links from there and you should be set.
Have fun.
