RCU Forums - View Single Post - OS SF 61 ringed
Old 09-15-2005 | 08:25 PM
downunder's Avatar
downunder
Default RE: OS SF 61 ringed
ORIGINAL: Flyboy Dave
Don't be confused....the 7M is a different carb. I pictured the 7D. Set the screw
in the middle....
( Hi Brian )
Dave.
Ah...OK...it seems the 7L (which I presume is what you've pictured and not the 7D?) is a simplified version of the 7M that I played with so it doesn't have the mid range adjustment. For some reason the 7L is missing from the carb manuals at http://www.osengines.com/manuals/index.html
The problem with the carb on the engine I was given to try to sort out was that the yoke had been fitted upside down. The flats that key to the spray bar to rotate it are set at an angle which meant that the metering slots were out of alignment so it was impossible to set the idle mix. Never having seen one of these carbs before it took a while to figure out
