Aileron Problem
If both sides are damaged,cct out damaged area and replace with hard wood,spruce,basswood,etc,I usually do this on building,then epoxy in place.If one side is damaged mix a mid or slow cure epoxy with milled fiber glass,fill the area almost full ,after it sets,even void with a filler,sand recover area,check trim,go fly.
ps.the glass makes it very strong.
