RCU Forums - View Single Post - speed records???
Old 09-16-2005 | 12:15 PM
  #48
EASYTIGER
Banned
My Feedback: (119)
Default RE: speed records???
ORIGINAL: Robrow
I'll tell you how it can be achieved without the use of monster power or some super-duper ptfe coated airframe....build yourself a WIG(Wings In Ground effect) machine such like the Russian Caspian Sea Monster or the many other wild and wonderful creations of all shapes and sizes that exploit this concept !! Then learn how to fly very fast right down around 25% of your wingspan off the hard deck!!
Probably best done over flat calm water with the use of giros for stability. You will get all the speed you need and mach 0.5 would be a walk in the park.
The Caspian Sea Monster needed it's 8 massive forward engines to get up to speed but once there in the hugely reduced drag zone of ground effect.... all 8 engines were shut down and only the 2 small tail mounted engines needed to sustain.
In theory even the best low drag high speed airframe can only achieve half the drag coefficient of a well designed ground effect machine.
Food for thought.
Rob.
If you will just send me the ten engines, I will get started on it right away! Two of the engines can be small, the ones on the tail, I don't mind. I have plenty of balsa, I don't mind scratchbuilding, and I have access to a private lake to fly it on!
I can PM you my adress so you can get those engines shipped out!
Cool plane...as far as I know, nobody has built an amphibious model turbine aircraft, a Convair Sea Dart would be cool. Throw in one more of your nice engines and I will do that one, too!
