RCU Forums - View Single Post - Carl Goldberg Ultimate building tips needed!!!
Old 09-16-2005 | 05:08 PM
camss69's Avatar
camss69
My Feedback: (46)
Default RE: Carl Goldberg Ultimate building tips needed!!!
Hi Steve,
That's why I like the setup I used, I used the stock servo mounting holes. (with exception of the throttle which only took two blocks) I removed the covering on the bottom of the plane where it's open and was able to fit the braces inside the fuse through the existing holes. The holes for the pushrod exits are the stock holes also. My setup only cost you the pushrods and some scrap 1/8 plywood.
I just can't see using the stock setup though.
To each his own I guess...
Take it easy..
