Wren 54 Specs
Hi there
I have just Bought myself a Wren 54 (mk2 i think). i want to know what the max and min RPM the turbine can run at, also what is the max temp it can run at. i am using locally produced electronics (GB Electronics, South Africa). it seems to work fine. the rpm must be set as it cuts at 140 000 i am to scared to crank it further. also when i increase throttle when i reach 3/4 throttle it cuts. must i set a throttle curve?
Thank you
Michael
