Hi Michael,
Here's the parameters I currently use on my setup:-
START/AUTOSTART
Start Allowed Revs = 7
Start Allowed EGT = 100
Startramp = 65
Disengage RPM = 30
Gas Off RPM = 35
HOLD/SHUT VALUES
Minimum Hold Revs = 50
Maximum Hold Revs = 160
Shut Revs - Lo = 20
Shut Revs - Hi = 170
Shut EGT Lo = 150
High Hold EGT = 680
Shut EGT - Hi = 800
RAMPING VALUES
Ramp Switch - Lo = 15
Ramp Switch - Hi = 85
Ramp Up - Lo = 4
Ramp Down - Lo = 6
Ramp Up - Mid = 5
Ramp Down - Mid = 5
Ramp Up - Hi = 4
Ramp Down - Hi = 4
PHYSICAL VALUES
Glow Driver = 240
Pulses/Rev = 1
Make sure you run through the "Learn R/C Parameters" for your particular transmitter.
Good Luck!
Regards
Scott
