hey you guys i have a different issue:
i put the 2.4 on my new extra 260 H9.
due to the engine distance from the end of the cowl i had to extend the engine mount with a rubber/shock absorber kind of type mounts.
wow....
i get lots of vibrations?
any ideas?
what should i use and were i can get it? link?
the distance from the firewall is 1.5!QUOT! in order to the prop shaft to be outside the cowl 1mm...!!!!!
CG is fine this way so i don't want to shorten the cowl and to bring the engine closer to the F.W.
thx
