RE: g-26 problem
How long did you let it run with the choke closed before you opened it? Brand new engine, not warmed up, maybe set too lean on low end or both low and high.....
Does it run rough as long as it is running, or does it do okay as long as the choke is closed? (like normal closed choke running--lot of smoke, gassy smell, won't rev freely, etc)
