Hey SydDythers, the little half moon points towards the needle valve screws and you might want to put a dab of blue loctite on the screw.The white reed block can be installed either way.If you have the carb update, the black spacer has the pulse vent facing down.My reeds are all closed tight so the gap in the reeds may affect performance. I have read about open reeds in other threads and I think you can carefully unsnap them and turn them over. Hope this helps, good luck.
ORIGINAL: SydDythers
Hi,
Couple questions on the DA50 WT201B Carb. When reattaching the throttle butterfly plate to the throttle arm, does the tiny half moon shaped cut out of the bottom of the plate point to the top of the pulse line valve on the top of the carb or down towards the needle valves? Secondly, when disassembling the carb, the white plastic housing for the reed valve pulled out and I'm not sure if I inserted it back into the plastic housing upside down or not. Is there a way to tell?
While I'm on the topic, I was inspecting the reeds and they don't appear to be completely seated. A couple of them seem to have 1/2 mm gaps. Does this affect performance?
Thanks!
John
