i have entered the new specs. i get gas to ignite but then the pump does not switch on? the temp runs to 800 then cool down starts.
must i replace the pump, or what setting should i do. cant i set the max RPM when turbine is off? i got it going sort-off but the RPM kept climbing. i went above 160,000 then cool down. must say this turbine was built by another chap from the kit about 3 years ago. that is why i am scared the thing will blow up.
could the turbine be dirty inside.
would you guys recommend i update the software of the TCU.
Michael
