RCU Forums - View Single Post - Cutting prop driver key-way
Old 09-19-2005 | 12:35 AM
Rupurt's Avatar
Rupurt
Default RE: Cutting prop driver key-way
Flypaper, thanks that sounds like less work.
"use lapping compound on the fly wheel and lap it on the shaft and you dont have to use a keyit worked for years on my briggs &stratton go-kart engines (12000rpm"s) good luck " the shaft is not tapered so this is not likely to work for me, thanks anyway.
Dave, A swiss file, is that like a needle file?
