Martno-
Check to make sure you have good pressure coming from the tank. You may have a hole or split in the pressure line, which could cause the engine to die in a loop. Also check the fuel supply line inside the tank.
Keep up the good work. I'm still thinking you're a few flights away from being ready for the bipe.
-Scott
