RE: Holy Smokes!!!!
If you do, run a check valve from the propane line to the vent on your smoke tank. Then use the jetcat valve to pulse smoke on and off. The pressure from your propane tank will keep constant pressure on your smoke tank against the valve, then when you crank the solenoid, you'll get the quick bursts you are looking for.
