RCU Forums - View Single Post - Engine ??????
Old 09-20-2005 | 04:07 PM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: Engine ??????
ORIGINAL: lnc0321
Every time that i accelerate it shuts off. I try to lean it and same result. I have still havent been able to run two full tanks on my hammer. Ran my first tank for breaking in the engine( two full turns from fully closed) and it ran fine but my second tank i lean it 1/8 of turn and it sarted to shut off every time. Also I have change my fuel tank for my second tank or could it be my glow plug (it glows bright). Any advice on what could i do?
I don't have one of these, but according to the manual, you're supposed to start with the needle 2.5 turns out. If you started at 2 turns out, it was probably already too lean. Try opening it up to 2.5 and then gradually lean it. Something to remember is that lean running will quickly wear an engine out due to excess heat and lack of lubrication. You want it to always be a little rich. As OB said, you want it to hesitate a bit when you rev it up on shore.
