ORIGINAL: BMatthews
ORIGINAL: Old Sourdough
Hmmmmmmmmmmmmm! That's a bit strange. I wonder how those lines through the last half of my previous post appeared there.
Go back and edit your post. You'll probably find there's a square bracket combo with an S in the middle or similar where you messed up the closeing of the brackets.
Bruce,
That was the problem. It occurred as a result of my using the sqare bracket with an "s" in the parenthetical phrase. Unfortunately, this is the way I was taught to do this in school.
I'll try not to make the same error again.
Thanks.
