RCU Forums - View Single Post - Starting first Kit-Sig 4 Star 60
Old 10-29-2002 | 01:12 AM
dbow's Avatar
dbow
Default Starting first Kit-Sig 4 Star 60
Well If any of you have seen my other threads I have been researching for a bit on both the 4 * and the Venture. I had previously decided on the Venture but changed my mind at the last minute. I have the 4 * kit on my table right now.
I have read over the instructions several times and Im just now looking over the parts as I take them out of the box.
I seem to have run into a problem before I have even started.
On page 8, Step 1 it talks about 6 1/4" x 1/2" x 36' balsa sticks.
I found all 6 of these however 2 of them seemed to be very, very flexible compare to the others. So much so that one broke into 2 pieces as I flexed it slightly. I could not believe it broke with so little pressure.
The other 4 sticks seem to be quite stiff and seem to be in good quality.
I am intending to contact SIG customer service to ask for replacement pieces.
I also found a Balsa trailing edge sheet that was torn down the center.
Guess Im about to find out about SIG customer service. Worst case is that I just run down to the Hobby shop and grab some replacements for a couple of bucks.
I will be posting on my progress as I build. Already looks like its gonna be a while.
Dbow
