RE: Hangar-9 p-51
I think if you want retracts, you will be better off buying a plane that is designed for them. The landing gear design for this trainer Mustang has the gear hard points far back on the wing. If you put retracts on this wing, you will need to do some extensive redesign and rebuilding of the wing to put structural strength where it would be needed. I know it's easy to forget, but this is, after all, a trainer.
