RCU Forums - View Single Post - FS8 Receiver Sensitivity and Range
Old 09-23-2005 | 11:27 PM
JettPilot's Avatar
JettPilot
Default RE: FS8 Receiver Sensitivity and Range
Thanks for the reply greg That is awesome, I hope I can get that kind of range from mine [X(] I will take you up on your tech support offer I love the FS8 and would not use anything else if I can get the range I need out of it, maybe it is my transmitter module that is causing the problem [&:] I am using a JR PCM 10X
BTW, I have the 50 MHZ FS8, acutally two of them and a CP4 also Would you expect the same range with the 50 MHZ unit as you got on the 72 MHZ unit ??
JettPilot
