RCU Forums - View Single Post - 1/4th Scale Flair Tiger Moth Project
Old 09-24-2005 | 05:15 PM
  #65
Square Nozzle
Default RE: 1/4th Scale Flair Tiger Moth Project
Back again to the Flair Tiger Moth. I just started building mine. I'm on sheet 1 and already have a question relating to mounting the engine and the tank position. I don't have the engine yet. Cybertom and/or Ed, where does the engine mount relative to the mount beams? Does the engine hang from the top of the beams or does it bolt to the bottom of the beams. Did you have to use the #16 formers to adjust tank height up or down or is the tank positioned properly relative to the Laser 150 carb with the as supplied formers?
