RE: 1/4th Scale Flair Tiger Moth Project
Thanks Ed. After I posted the inquiry I found a sketch in the build instructions that discusses putting a baffle around the engine. In that sketch it showed the engine mounted as you stated. I have an inquiry in to Laser to get the carb to crank shaft center line dimension.
I share your decision about the tank. When I saw the stopper set up on the kit tank, I decided I'd be installing a Sullivan round tank.
