RE: muclloha mac 80 -a
g'day davewallace
'down under' we use millimetres. n e way, when i fixed it i only had to remake one of the mounting points. with the coil, i tried over and over again using different thicknesses of paper and card. the best i got was a weak spark but it only came up every now and then. the other problem might be because it was straped to my bike it jumped around alot. the coil and the flywheel knocked against each other all the time and now they are both worn a little bit. so with this info any other ideas? also i am putting a 25.6cc 'pope' motor (dont know what there called there) into a car and was wondering if leaveing the flywheel and coil on there would be alrite. any tips on this idea as well would be great.
