RE: muclloha mac 80 -a
hi again,
its like you red my mind! but instead of putting the sproket on the clutch i was going to put it on the shaft and run an outboard bearing. im making the car from scratch though. im going to build the chassis and the wishbones for the front out of ally and not going to run any suspension on the back. if you've seen the raco jac rabbit then you'll get an idea on what im going to make it look like. im also going to run the chain straight to the back axel with a 2.5:1 ratio. any pics of yours while you built it would be great so i can see if its anything like what im making.
