RCU Forums - View Single Post - Double Taco
Thread: Double Taco
Old 09-27-2005 | 12:42 PM
johnyh
Default Double Taco
Initially this was to be a "winter project" but a weekend of bad weather brought this forward, however it may not be completed until after winter.
The idea started as a discussion on the flying field "what if...." extended the wings,....... two fuselages, two engines.....
I already had the plan for a small .25 sized profile, "Taco" from Paul Swaney. This had progressed from my fascination in flying profiles and owning a Mojo 60 already from the said Mr Swaney's stables hanger.
Then Just Engines ran a two for one engine deal so two .25s were ordered.
The first stage was to draft the extensions to the wing. With some slight deliberation the centre section was created to accommodate two props with a little space between.
I then set about preparing the parts. I was partly lucky in that Paul had provided the wing wibs.
I'm well into the project now so I'll progressively load the build,(if anyone's interested), over the next few nights.
The plan shows a 91/2" mid section extension
[img][/img]
