RCU Forums - View Single Post - Spoilerons
Thread: Spoilerons
Old 09-27-2005 | 06:33 PM
smokingcrater
Default RE: Spoilerons
here is an even better spot, MUCH better IMHO. put the spoilerons/flaperons on the left shoulder slider, giving you variable control. My hand is on that almost as much as any primary flight control. especially good for landing, kill the throttle up high, glide around for awhile, then use that to drop in at your feet, reflexing the ailerons up to drop like a rock or dropping them way down to float on in.
I've got mine set up that with so much mix that in the full up or down position the servo is at the end of its travel. aileron control only moves one surface! (yeah, not very controllable at that time, but they work great as speedbrakes in vertical dives!)
ORIGINAL: Josey Wales
ORIGINAL: daveopam
TSuppa, I have the 9C and use spoilerons on several planes. If I could offer two cents.............I found that using the trainer switch is the best place to put the spoileron mix. With 100% mixed in the plane can be difficult to handle. SO I pull the switch,perform the manuver, then let go of the switch and fly out. I mostly use this mix for elevators. When I had the mix on a regular switch I was having to stand the plane on it's nose till I could flip the switch back.
David
I totally agree!
