Shogunmst,
Thanks for contributing, but the repair is completed. A little bit of RC 56 canopy glue carefully applied worked quite well. After the initial repair cured I double checked both sides of the crack and filled any gaps. When completely dry a 1/2" wide strip of vinyl left over from my graphics package carefully placed across the rear of the the canopy over the top of the repair did the trick. Unless you knew it was there and were specifically looking for it, the finished repair is not noticable
