RE: Freestyle Rush....Does Everything....Why buy a big plane??? VIDS
Hi All,
I am about to mount an OS 50 on the firewall of the Freestyle Rush. I plan to use a 12.25 x 3.75 propp. What thrust angles are commonly being used for this plane for typical pattern and 3D? Also does anyone have some photos of their installation as I was supplied with the wrong manual in the box and I am not sure of servo placement. For example, although there are two servo cut outs at the back of the fuselage, the servos would hit eachother if they were installed together. Also, does the long steel cable indicate that a pull pull is used?
Anyway any help or photos of installation would be appreciated.
Cheers
Lang
