RE: Programming a JETI ESC with the Program card
Unless it is an Opto ESC, you don't use the receiver battery but rather plug a flight pack into the main power wires.
Be sure that the motor is connected to the ESC to hear the beep. It happens about 1 second (or less) after connecting battery power.
Only use the 4-cell receiver battery connections on the upper left part of the card with OPTO-isolated Jeti Advance PLUS ESCs.
Good luck!
