RCU Forums - View Single Post - HOW?? to take off and re-insert carb in Genesis engine
Old 09-29-2005 | 12:42 PM
RunX
Default RE: HOW?? to take off and re-insert carb in Genesis engine
O.k i see.I had the same problem with my carb.The silver metal sleeve that you will see when you remove the carb comes loose and then the the carb twist and that is why it moves.I took a longer bolt with a washer where the the original bolt use to be and thightened it all up but be carefull not snap it off.
