RCU Forums - View Single Post - HOW?? to take off and re-insert carb in Genesis engine
Old 09-29-2005 | 01:13 PM
abonnet
Default RE: HOW?? to take off and re-insert carb in Genesis engine
RunX, what bolt are you talking about? the one that is used to adjust the idle?
and, which "canal" does the idle screw goes into? the slim one that goes across the length of the barrel, or the short, deeper one that is closer to the end of the sleeve?
also, when I look down to into the carburator hole, should the end of the sleeve look concave or straight?
seems I got myslef into a pain in the ***.
