RCU Forums - View Single Post - Genesis pattern plane
Old 09-29-2005 | 03:55 PM
  #52
flyboy91
Default RE: Genesis pattern plane
The pushrods I used where actually hanger 9 titanium pushrods for both the elevator and ailerons. Then use dubro ball links but make sure you get the ones that are a 4-40 thread but a 2-56 bolt through the ball as it is much lighter and littler. Then just use the control horns chip supplies but I have found that if you take the ball bearing out they will work much better as the bear shields have tend to come out so knock the bearing out and use the spacers supplied in the ball link to fill in the hole on the control horn. I will try and post some pics tonight.
Andrew
