Genesis pattern plane
#51
Hey Andrew can you tell me what you used to set up your Genesis? What pushrod did you use and what linkages did you use for the aileron and elevator?
Thanks in advance
Thanks in advance
#52
The pushrods I used where actually hanger 9 titanium pushrods for both the elevator and ailerons. Then use dubro ball links but make sure you get the ones that are a 4-40 thread but a 2-56 bolt through the ball as it is much lighter and littler. Then just use the control horns chip supplies but I have found that if you take the ball bearing out they will work much better as the bear shields have tend to come out so knock the bearing out and use the spacers supplied in the ball link to fill in the hole on the control horn. I will try and post some pics tonight.
Andrew
Andrew
#53
Andrew, did you use the 2 1/2 inch pushrod for the elevator and the three inch for the aileron? Do you have any pics of your set-up?
thanks
thanks
#56
IN
I'm sure Andrew will get back with you guys, he's been busy preparing for Tucson, practicing packing and shipping planes, competing, going to college and work, I know that your questions are very important to him, but there are other priorities that take precedence.
Steve Maxwell
Steve Maxwell
