RCU Forums - View Single Post - Help getting PAW 80 started!!
Old 09-30-2005 | 02:55 PM
tag-RCU
Default Help getting PAW 80 started!!
I have a PAW 80 that I am having trouble starting. It seems to take a lot of compression to start and then when it does, it labors and runs real slow. Any changes in the compression or needle valve kills it. I get the same results using either home brew or Davis fuel. How high/low do you need the compression to be in order to start? This is my first attempt at a deisel and the engine is second hand.
Any help would be appreciated.
Tag
