RE: New Kyosho Oxalys 50 ?
Hi,
Thanks for the reply. I bought it today it looks very nice, fuselage is pretty wide and tall. Yes I will use OS-70 Ultimate with pump which currently sits on another plane. You're right 3D is probably not possible, ailerons are not full span and tail surfaces are not enough for 3D. Stabilisers seem smaller than other planes of that size.
I'm participaiting in a local Pattern contest (novice class) in 3 weeks time, I was planning to use my Showtime but I'm using a top notch setup there and will not have many flights till the contest. I'm not gonna risk it as my YS-110 will not be broken in completely till then.
On Oxalys I'm going with the following setup please let me know if I made a wrong choice.
Engine: OS FS-70 Ultimate Pump (What prop really? Is APC 13x7 ok?, I found one on my bench)
Fuel: Cool Power Heli 30%
Servos: Ailerons JR-517 (0.27 sec, 3.1 Kg), Rudder and Elevator JR-591 (0.24 sec, 5.1Kg), Hi-tec HS-81 Mini on throttle
Battery: JR-1100mAh
I know my servo selection is basic, but will it do the job for the novice category?
Rgrds,
Nick
