RCU Forums - View Single Post - Vector Flight Xtra 300 66" build
Old 10-01-2005 | 06:45 PM
  #83
RVator
Default RE: Vector Flight Xtra 300 66" build
Hi this Suit on RVs pc. I haven't had the chance to maiden yet. The engine wouldn't run very well last time out. I found the elevators already loose from the soft balsa and am in the process of scabing on some light ply to strengthen them up. When testing the engine useing the tail trap, it dented the horizonal stab pretty bad from the balsa being so soft. My fuse is crushed in two places and I haven't even flown it yet, again from being so soft I believe. It seems each time I work on it I find something else that needs to be addressed before I can fly it. I plan to strengthen the rudder also because I don't trust the balsa to hold the little horns with two screws. I'm changing them to the H 9 ones that came with my US 120. Anyway, if and when I finish modifying this thing I'll maiden it and let you all know how it flys.
