RCU Forums - View Single Post - Powerline Edge is on the Way
Old 10-02-2005 | 01:44 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Powerline Edge is on the Way
Sounds good guys. Thanks for the help.
I was thinking about 2 elevator servos because I'm using a heavier engine than most of you probably are. I'll just have to see how it's gonna balance with the engine and servos.
So, HS-475 on the ailerons. JR- 4131 on the rudder. HS-81 on the throttle. Probably gonna use 2 of the HS-77 LP on the elevators if it will balance. If not--then a single JR-4131 or 8101.
RX is Hitec 555. Hydrimax 1200mah 6V MH battery with Hobbico HD switch and extensions.
