ORIGINAL: Nightz
JF,
I notice the fuel tubing out the bottom of your bipe.....whats that!?
How's your tank setup?
Also, did you do the stock split rod for the elevator setup?
-Rocko
Fuel tubing out the bottom is the filling line, supplied tank gives you option of having 3 connections, so I chose to use all of them.
Yep i used standard setup, even used supplied clevis' ........not something that i'd usually use from an ARF kit, them seem ok, but i'll keep checking them!
J
