I'm new to RC and I have just about completed building my reflection. One question though, about the prop and the prop spacer. BTW, I'm using the stock motor and prop setup(not the rimfire, but the stick mounted). The instructions are a little abstract: it says that the spacer should go into the rear of the propeller hub. It doesn't fit into the prop itself, so does that mean I should put the spacer on the propsaver/spinner thing? I probably sound like a retard so thanks for putting up with me. I just want to make sure I do this right.
