RCU Forums - View Single Post - Building a Sig 4*40....please support
Old 10-03-2005 | 11:50 AM
argileh
Default Building a Sig 4*40....please support
I started building a Sig 4*40. Its my first kit as I have never built one before.
I started with the right wing. I made some progress over the weekend. I installed/glued all ribs plus the T.E. I am now ready to install the rear top sheeting. The instructions recommend using Sig Bond (Aliphatic resin) at the joint between the back of the sheeting and the T.E. as it is easier to sand. So now I have two questions:
1) My LHS did not have the Sig Bond so he sold me Titebond (not Titebond II). Is it ok to use it, or should I get the Titebond II.
2) Is this glue applied the same way with CA, i.e you fit the parts and then apply the CA to the joints where it will penetrate, or do you trial fit, remove the part, apply the glue and then reinstall.
Any help is much appreciated. Thanks
Note : I am trying to upload some photos but unable to do so . Will keep trying
