Building a Sig 4*40....please support
If you take your time and let the debonder do the work, it can be done. It may be tedious. You need to decide if it is high enough to cause a problem as it is now.
Just sand it, I wouldnt waste the time removing it. You said it was about 1/64th. 1/64th off a 1/4 or 3/8 piece
of balsa is not going to hurt it. 80 grit should make quick work of the 1/64th of balsa.
