RE: Building a Sig 4*40....please support
argileh:
Congratulations on your decision to build a kit. I found it to be a very rewarding experience.
As far as the glue is concerned, I found that using the slower white/yellow glue was advantageous for me as a beginner because it forced me to slow down. It also fit my schedule quite well, since all I had time for was putting in and hour or two every night. This way, while the glue was drying over night I could start reading/planning the next step and not rush into the build.
I'm sure that more experienced builders can build successfully (as mikeboyd pointed out) kits from start to finish in 40 hours using CA, but you probably will be better off with the slower process of using your Titebond.
Just my 2ยข
Good luck, and please post some pictures as you progress.
-tychoc
